I have a 2007 Honda Civic with over 200k miles. When I turn on the headlight, tail lights don't turn on. Turn signal light works fine, brake light works fine and reverse light works fine as well. I don't understand why the tail lights won't turn on. What can possibly cause this problem?
| improve this question | | | | |
  • A faulty switch possibly... – Solar Mike Mar 23 '19 at 21:51
  • Or a wiring fault in the + wire that carries taillight current from the dash/fuse area back to the rear end of the car. – DavidSupportsMonica Mar 24 '19 at 2:20
    Have you checked the fuses and relays? – Pᴀᴜʟsᴛᴇʀ2 Mar 24 '19 at 13:18
  • Are the front marker lights working? Check fuse 15 – Moab Mar 26 '19 at 21:16
