Camry LE 2005, 171k miles. Got examined the brakes professionally by mechanic. He says only pad and rotor needs replacement. A non-professional-but-car-knowing friend is advising to get replaced the caliper as well (because of age of car he suggests I will need it soon). Should I get caliper replaced? Curent calipers are original that came with car.
  • Welcome to Motor Vehicle Maintenance & Repair! Commented Mar 22, 2019 at 1:29
Here's the litmus I'd use to figure this out:
  1. Are there any problems with the current calipers?
  2. Are the calipers leaking?
  3. Do the calipers retract after braking (if they don't retract the brakes will drag)?
If the answers to these three simple questions are "No", then don't change them. Calipers will continue to work as long as they work. They are one of those parts which really do not have an expiration date ... well ... until they expire. IMHO, don't change them until you need to change them.
