I'm looking to buy a 2014 Jeep Grand Cherokee and during the visual inspection I noticed this plate sticking out of the undercarriage. Everything is more or less the same level on the undercarriage except this plate and it also looks weirdly bent.
Is it in a normal condition or is there cause for concern?
Jeep undercarriage
  • 3
    Heat shield for the catalytic converter, looks like it got bent down a bit.
    – Moab
    Mar 19, 2019 at 21:05
    Sounds like an answer, @Moab.
    – JPhi1618
    Mar 19, 2019 at 21:13
It is the Heat shield for the catalytic converter, looks like it got bent down a bit.
  • Thanks, any concerns with continuing with it in this bent shape? Likely causes? Guess scraping against a rock or something? Should I avoid the car?
    – The Texan
    Mar 20, 2019 at 20:08
  • Its no big deal, it can be easily bent back into position. I have no clue how it got that way.
    – Moab
    Mar 20, 2019 at 20:11
