I have a mazda protege 5 that will only start in nuetral and i need to know if it is possible and safe to drive after starting my vehicle this way?
  • So after its been started in either D or N, i can then drive where-ever as if i had started it in P? – mermaidshell83 Mar 19 '19 at 18:25
  • Have the neutral safety switch replaced. – Moab Mar 19 '19 at 21:07
If this is an automatic then it should only start in P or N.
If it is manual then it may only start in neutral and, on some cars, when the clutch is pushed down.
Yes, you can drive the car without further damage. I would start the engine, however, only when the gearshift is in N.
An automatic transmission car should only start in P or N. To return the transmission to correct functioning, the transmission's neutral safety switch should be adjusted or replaced.
