I have an 04 Accord that wont start. There have been two times the past month or so when it was like -20 degrees out and I had to jump it to start. The other day, its like 40 degrees, and it wont start. I'm thinking, well it must be the battery. So I buy a new battery and that doesn't solve the issue either. I had the battery tested and its good--checked all the connections/grounds. All my dash lights/radio work. The wipers work, albeit a bit slow. Replaced the starter relay--still no luck. Any thoughts? Here's a video of what it's doing: https://streamable.com/yh1nr
  • How many miles on the vehicle?
    – zipzit
    Mar 18 '19 at 4:33
  • Sounds like it has no compression, maybe the timing belt broke.
    – Moab
    Mar 18 '19 at 20:57
  • @Moab It's a 2.4 so a chain. Agree on the compression. Time to do a compression test.
    – Ben
    Mar 18 '19 at 21:27
