I have a grand Picasso 1.6 HDI 9HZ engine recently i have rebuild the engine by replacing crankshaft and piston rings and but i want to know how can i adjust firing order to put on timing belt ?
    Welcome to Motor Vehicle Maintenance & Repair! Is there an underlying problem you're trying to solve here? I'm not quite sure why you'd need to change the firing order? Or is the issue you need to change the overall timing? How do you know you need to change any of this? Why would changing out the crankshaft and piston rings make it any different than normal for putting a timing belt in place? Mar 14, 2019 at 17:59
  • Do you need to time the camshaft to the crankshaft - is that what you mean?
    Mar 14, 2019 at 18:52
