My washer pump does not work on my 02 Accent. I checked the fuse panel under the dash, fuse was ok. I checked the box under the hood, everything is good. Can anyone tell me what the 3 wires that go into the plug for the washer pump are? I know one is orange, one is brown, and one is blue with orange or brown stripe. I have a new factory replacement pump. (98510 25100) The factory connector was cut off. I need the pin out to wire correlation. Any help would be great!
  • The wiring has been cut off of the current one? or the new one? If it's the new one, you could use the existing one as a pattern? – Nick C Mar 14 at 16:30
  • Thanks but the original one has been cut off. I was hoping to find someone that has the same make and model and send me a picture or discription of wht wire goes to what pin on the original connector. – BVBN Mar 15 at 17:25
