From the last few days, I am having this issue wherein my rear disk brakes are getting jammed and the brake-pads do not disengage.
The bike does not move and the disk plate get red hot. I have keep it for some time to cool down after which the bike can be moved again. I will take the bike to the service center soon.
I would like to know the reasons for the same and also what could be the solutions. Thanks.
    This is a rampant issue with this motorcycle model , the design is inherently flawed.
    – Shobin P
    Mar 14, 2019 at 7:36
There are a few possibilities:
1) the pads are sticking in the caliper - possibly corrosion or dirt
2) the pistons are sticking / seized in the caliper
Whichever, this needs investigating and correcting - pads sticking will be less expensive...
  • The issue was the second one. I changed the whole rear brake assembly and now everything works like a charm. Jun 28, 2019 at 18:37
  • @NamanSharma well done, good luck.
    Jun 28, 2019 at 18:44
