While kickstarting the motorcycle, the engine starts properly. But after travelling some distance, the engine sputters and turns off even when there is sufficient fuel. Then, after few raises to the throttle, the engine works properly.
The carburetor is working fine, which I recently checked.
What could be the reason behind this?
I own a BAJAJ CT100, which is a 100cc motorcycle.
