If i've takin the ABS out of my 2000 4runner will it cause to not shift? What I did was take a 2000 4runner sr5 4 wheel drive and took the four by transmission out and put a 2 wheel drive transmission in and made it 2 wheel drive and now when I put it in gear no matter D,2,1 it will only stay in first gear. I have park, reverse and first gear only. Any help would be greatly appreciated.
Welcome to Motor Vehicle Maintenance & Repair! Is the transmission electronically controlled? If so, there may not be a command for the transmission to shift from first to 2nd to 3rd and so forth. – Pᴀᴜʟsᴛᴇʀ2♦ Mar 12 '19 at 10:31
I assume you connected the electrical plugs all as they were before? – EᑎOT Mar 12 '19 at 23:20
I got it fixed. The speed sensor was bad and not allowing it to shift. – Tone LeVeck Mar 22 '19 at 2:55
