Why don't my brake lights and rear turn signals not written on my 2005 town and country. My hazards and tail lights do work.
Check for blown bulbs first, then check for blown fuses, then broken wires at the rear... and that’s the order I would take...– Solar MikeMar 12, 2019 at 5:27
I did check bulbs and fuses haven't checked wires at the rear. Where should i be looking?– Laura HarkinsMar 12, 2019 at 5:31
Did you replace the bulbs with ones you know are good?– GdDMar 12, 2019 at 10:33
If hazards are working then the bulbs are good for brake lights and turn signals also. More than likely a bad turn signal switch.– MoabMar 15, 2019 at 22:49
