I have a 2005 model nissan altima 4 cylender2.5. My car will turn over just won't crank we have replaced a crank position sensor changed coil pack and spark plugs it just won't crank checked fuel pump and filter both seem to be fine
  • Welcome to Motor Vehicle Maintenance & Repair! Mar 7, 2019 at 22:49
  • How many miles on vehicle? When was the last time the car was running?
    – zipzit
    Mar 8, 2019 at 17:11
  • What was the symptom before you performed the repairs? Or is this a new problem since the repair? Put a timing light on a plug wire and see if it fires when cranking. State the result. You can put the timing light on the low-side of the coil if there is no high tension cable. (The timing lights I used could pickup the 12 volts on the low side and fire the light. They were Mac and Snapon timing lights).
    – jww
    Apr 15, 2019 at 16:25
