Every once in a while, a drop of motor oil will get on the timing belt or serpentine belt when adding motor oil.
Is it a good idea to wipe it off right away?
If so, even after wiping it off, some motor oil residue will remain on the belt. Is this an issue?
  • Put a cloth or paper before pouring oil and avoid the problem.
    Mar 7 '19 at 17:24
No, it is not an issue.
Serpentine belts are very tough. Motor oil will not harm any rubber in or around the engine.
Wipe it off to keep the engine bay clean.
