I have a 1997 S10 I'm thinking of doing a V8 swap with in the future does anyone know if the flywheel off of a 4.3 Chevy would work on a older 350 Since they’re basically identical minus 2 cylinders or if a NV3500 transmission would bolt right up to one of the newer 5.3 or 5.7 vortec/LS blocks
Off the top of my head, I'd say no it's not. I'm sure the balance on it is completely different for the V6 than the 350. It would bolt up, but you'd have all kinds of vibration. I'll double check when I get home and give you a real answer if someone else hasn't done so already. – Pᴀᴜʟsᴛᴇʀ2♦ Mar 4 '19 at 23:11
Only difference in later model 350's (5.7) and 4.3's is either it is a one piece or two piece rear main seal crankshaft, the flywheels are very different on how they bolt up and the One piece crankshaft engines (5.7 and 4.3) are externally balanced so they have a counterweight. – Moab Mar 5 '19 at 21:55
As far as the flywheel itself goes, you can fit it behind the engines of the following vehicles:
CHEVROLET BLAZER 1995-2004
CHEVROLET C1500 PICKUP 1995-1998
CHEVROLET C2500 PICKUP 1995
CHEVROLET K1500 PICKUP 1995-1998
CHEVROLET K2500 PICKUP 1995
CHEVROLET P30 1990-1995
CHEVROLET S10 BLAZER 1990-1994
CHEVROLET S10 PICKUP 1990-2003
GMC C1500 PICKUP 1995-1998
GMC C2500 PICKUP 1995
GMC JIMMY 1995-2001
GMC K1500 PICKUP 1995-1998
GMC K2500 PICKUP 1995
GMC P3500 1990-1995
GMC S15 PICKUP 1990
GMC SONOMA 1991-2003
ISUZU HOMBRE 1998
I believe these are the engines with the one piece oil seal, so the newer V6/V8 of the SBC Gen 1 design. I was wrong in my comment in that it is weighted the same between the V8 and V6 engines of this type, so you're good to go there. This flywheel will also not work with the two piece oil seal crank, so leaves out the older Gen 1 SBC's. The flywheel will not fit the Gen III/IV SBC's (LSx based engines), because the crank has a completely different bolt pattern on it.
As far as the NV3500 transmission, this should have the standard old style bolt pattern on it, which means it will bolt directly to any SBC design up through Gen IV (LSx based). The only thing is, the LS engines have a slightly different bolt pattern where one of the bolts is offset, which means you'd only get five bolts located to mount the transmission. This is not an issue as people do it all the time.
The only thing which would be of issue with running it on an LS engine is the spacing of the throwout bearing to the clutch forks. And with that, I'm really not sure how you'd overcome that. With the transmissions usually ran with the LSx blocks, you have a hydraulic clutch slave which sits inside the bellhousing on the tranny main shaft. You adjust it by shimming it. I can't tell you exactly how you measure it and what shims you'd use, but it all depends on how far back the throwout bearing is from the clutch forks.
All-in-all, you can make it work, but it isn't exactly easy. I mean, for some applications, it isn't just a bolt up, but rather it takes some effort and planning.
