I changed my headlights (low/high/parking) to LED, didnt like though thay all worked. Then changed to Xenon HID Halogen, didnt like though they all worked. Change back to regular Halogen & now the low beams, parking lights, & interior/dash lights wont come on. I replaced fuses & headlight switch for no change. The high beams & turn signal works & the fog lights only when high beams are on. ???
1 Answer
Did you check electric wiring diagram ? You probably have further fuse location . If not, check the Lightning module . Could probably have overvolted on my opinion
Where can I find the module? I've check online but no results on videos or diagrams. Mar 7, 2019 at 0:17
