Car is a 1999 honda civic vti coupe. I getting damp reappear quite quickly and am wondering if its cause im leaving it stationary/not airing enough or because I have a damp situation in the boot. If the boot section is separately contained from the cabin I imagine the damp can't make its way into the cabin.
  1. Are the boot and cabin separate containers and would damp in the boot cause damp in the cabin? I haven't been able to have a proper look because smell is so bad in the boot its making me ill, but just want to know what you expect\the general case.
  2. I have attached a picture of the wheel in my boot. You can see there are lots of white spots, are these damp spots and what would be an effective, preferably natural way to move them? Does the rubber on the wheel need to be treated in any way in case its absorbed anything?enter image description here
No - it's vanishingly rare to find the boot being a separate weather-tight compartment from the main cabin.
Yep, the rear seats are going to inhibit some of the movement of the damp but not all.
As for how to tackle the issue in general - there's multiple places to check:
  1. Rear window seal - make sure the rear window seal is good. This can be checked by recruiting a friend to watch from the inside of the car and pouring water over with a hose pipe.
  2. Boot seal - the boot lid might not be sealing properly. Test with the same method as above (only this time the hapless friend is in the boot)
  3. Blocked drainage channel(s) - there should be drainage channels to cope with water run off from the rear screen, make sure these aren't blocked.
  4. Boot floor - check for corrosion/holes in the boot floor, water can come up through this when you are driving about in wet conditions.
To deal with the current dampness get everything out of the boot, give everything a clean and dry it down with paper towels. You might want to put a light scattering of cat litter in the base of the wheel well to act as a desiccant to help suck any excess moisture out of the air as well.
Yep, light corrosion as a result of the damp (possibly mold but I'd say corrosion is more likely)
Take the wheel out and clean it like you would a normal wheel on the car (make sure it's thoroughly dry before putting it back) - there isn't going to be a "natural" way of removing those, you've going to have to use some cleaning chemicals; Bilberry would be my first choice - not too harsh and very effective.
No not really, probably worth giving it a clean down with soapy water on general principles but tyre rubber is pretty hardy - it's designed to face much worse when in use.
  • Many/most cars also have holes in the floor with rubber plugs in them. I had one in my trunk work loose and I had a similar problem.
    – Tim Nevins
    Mar 4, 2019 at 16:02
I would check the rear window gasket and the gasket around the trunk area for deterioration/leaks.
Do the rear seats in your vehicle fold down? It's fairly rare that the cabin and trunk areas are completely isolated.
