my Renault megane scenic 1.4 has a squeaky and chirp sound and it also drips power steering fluid under the car on the floor it's visible. The cambelt also have a 2cm Crack on the edge of the belt. I identified all these things that should be fixed but I am not really sure what the cause is of the squealing and chirp noise. Please advise me. Thanksenter image description here
  • Are you sure it's the cambelt? It could very well be the crack is in the drive belt for the power steering pump. The cambelt isn't visible without the removal of a number of plastic covers. – Steve Matthews Jul 26 '19 at 8:30
They are sounds due to a loose or slipping belt - sounds warning you that it needs maintenance. And that cambelt needs changing - a cheaper option than waiting for it to break.
| improve this answer | |
