There is a leak at the rim of wheel for my scooter Suzuki swish The more it rides the more it seems
1 Answer
That "black goo" is from the failed hub or bearing seal.
It needs replacing and most likely the bearing as well.
This should be done asap, as it will breakdown.
Depends on your country parts may be very expensive or labor or both... Commented Feb 25, 2019 at 9:17
