How do I stop the flywheel from spinning while torquing the bolts?
My repair manual says I should buy a special tool to do it, but I don't want to buy an expensive tool that I'll rarely use. Is there a way to do this without any special tools?
Sign up to join this communityHow do I stop the flywheel from spinning while torquing the bolts?
The Internet wasn't helping me much on this one, so I came up with a trick:
(Closeup -- shown at an angle due to poor photography, but the bar is vertical)
Notes
Another user deleted an answer that is worth mentioning:
If you put a breaker bar on the nut at the opposite end of the crankshaft, it should be able to stop the shaft from turning when you torque your flywheel bolts.
Notes
A possible concern with this approach is that it might cause that nut to turn, as in this video https://www.youtube.com/watch?v=zDNzHELneWA, but it can certainly be done successfully.
I can't take credit for this but another option is to engage something with the teeth lining the flywheel. Using something like a board of wood would prevent scratching or gouging of the flywheel or other surfaces but other materials/tools could be used. Take this material and set one end against the teeth and one against the chassis or the ground. All you have to do now is spin some wrenches.
P.S. Credit goes to ChrisFix
Better use disc brake system on the flywheel. It gives effective results. But it has a disadvantage. I. e) wearing on the flywheel disc due to friction
