I have had the bulb indicator light on for a while now but I cannot diagnose it. I am interested to know what the light in the picture is (the rear passenger side light on the inside/boot door)? I cannot get it to light up even after changing the bulb so would like to know what the light does. It may be an electrical fault to that particular one.
PS it is not on - I had my camera flash on
Cheers
    That looks like a reverse lamp. The red circle surrounding it appears to be a reflector. I think these Golfs had a single reverse lamp on one side and a fog lamp on the other.
    – Jim Perris
    Feb 20, 2019 at 20:47
  • Welcome to Motor Vehicle Maintenance & Repair! Feb 20, 2019 at 21:33
  • I'm pretty sure that is a fog lamp indicator. Please try this test. Start car, turn on headlamps, low beam, then turn on fog lights. I believe that light is to make your vehicle more visible during heavy fog conditions. If not that, its possibly a parking lamp? (Is there a parking lamp setting on your lamp switch?)
    – zipzit
    Feb 21, 2019 at 15:46
  • Turns out it was a reversing light - so the mystery continues about the warning light!
    – AWGIS
    Feb 21, 2019 at 16:52
