We have checked sunroof and wiper drains and both are clear. But water continues to come in and soak carport.
  • What is model and year of your Lexus?
    – sam
    Feb 20, 2019 at 20:47
  • 2006. Sedan 360 I think. 4 door Feb 21, 2019 at 4:45
Make certain the drain for the HVAC housing isn't clogged. Do you hear sloshing noises when making sharp turns or lane changes?
Does this happen all the time, or only after a rain? If it's rain-related, check around the windshield for rust or gasket failure, and make certain the side window welting has no gaps.
Also, the sunroof drains might be clear, but also make sure they have not gotten disconnected or split where they join the gutter channel.
