2 tid ... I turn the key and the lights come on but won't start. After pumping brake and accelerator pedal it starts. I have changed the crankshaft sensor and all vacuum pipes and still same problem. any ideas or suggestions would be appreciated many thanks
  • Welcome to Motor Vehicle Maintenance & Repair! Your explanation of what's going on is a little confusing. If you could add any more information about how it behaves, that would be awesome. When you say it won't start, does that mean it doesn't even try to start (no crank) or that it cranks over but doesn't do anything as it's cranking (no other signs of life)? – Pᴀᴜʟsᴛᴇʀ2 Feb 18 '19 at 17:54
