I was out of town for a little over a week, while the weather has been below freezing. No access to indoor parking. Now that I've come back, the car won't start (no sound of the engine turning or anything) and the low oil light is on the dashboard while I'm turning the key.
I checked the dipstick (very low) and topped add about .5 liters of oil. It still won't start and the low oil light is still on. Won't be able to try a jump start for another 12ish hours.
Any advice? Should I try adding more oil even if it's above the minimum line on the dipstick now?
  • Welcome to Motor Vehicle Maintenance & Repair! Please contact the Community Managers to get your two accounts merged. Feb 18, 2019 at 14:36
  • I wouldn't worry about the low oil light when clearly the operating voltage of your car is WAY below normal.
    – mike65535
    Feb 19, 2019 at 12:12
Welcome to the site! Sounds like a flat battery to me - especially given you say it's not turning over at all.
The oil pressure light is a red herring in this instance I think -they typically illuminate as part of the start up process, you just normally don't register it as it it will go out when the car starts. Don't add any more oil at this stage.
  • The OP says the dipstick read low.
    – GdD
    Feb 18, 2019 at 14:22
    @GdD yep.. but if there is sufficient oil to register on the dipstick at all it is not going to cause it not to turn over. And they have added 0.5l already, which should be enough to bring the level comfortably into the "normal" zone. Feb 18, 2019 at 14:24
  • I see where you are coming from now and I agree, it just wasn't immediately clear from how you phrased it. The oil level won't be a reason it doesn't start.
    – GdD
    Feb 18, 2019 at 14:41
  • A jump start successfully started the car. Thank you for your advice!
    – cristiline
    Feb 19, 2019 at 6:19
