Ducati 450 scrambler 1975 converted to 12v with Luas Rita AB11 electronic ignition it is so easy to start with this modification I put a new original alternator 3 face that gives up to 55v at 5000rpm a new original reg/rec output 14v and the problem it is not charging the battery do you think that I have to do a diode after the battery or something?
Thank and I appreciate for help.
