Since the ac system is located mostly inside a car engine and the car is warmed up prior to adding freon, and the temp/humidity in engine bay is different from ambient temperature//humidity, and all of the above is done with car in parked position, why is ambient temperature used to measure pressure instead of temps closer to engine area with hood open.
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Feb 14, 2019 at 23:03
Because part of the a/c system is also in the car cabin and not under the hood.– Solar MikeFeb 15, 2019 at 6:23
Okay. But then why is the car cabin the least common denominator and not the car engine when measuring pressure.– StackUserFeb 15, 2019 at 19:34
Think about the a/c circuit - the compressor causes the pressure rise and the throttle or expansion valve reduces it.... where are those components and which components are downstream of them....– Solar MikeFeb 16, 2019 at 8:31
Try plotting the cycle on an H-S diagram and evaluating the presdures around the circuit based on the temperatures...– Solar MikeFeb 16, 2019 at 8:33
