My Peugeot 5008 has just failed MOT because of wrong front tyres size. The driver side is 215/40/18/85/W with (Tread, outside 5.5-centre 5- inside 5.1 mm) and the passenger side is 215/45/18/93/Y with (Tread, outside 3.1-centre 3.4-inside 3.5) and. The garage is on the wrong side since they chose and changed the drive side tyre seven months ago.
My question is; should that had a bad impact on the car during the seven months ago? I want to understand if there is anything else should be checked before replacing the wrong sized tyres.
    It could have been worse. You didn't crash. Seriously, having different sized tires on the same axle is just WRONG. Different speed ratings and load capacity isn't very clever, either.
    – alephzero
    Feb 12 '19 at 14:22
    And if you did have a crash, you then have to hope the insurance assessor doesn't notice - otherwise they probably wouldn't pay out on a car with a blatant automatic-MOT-failure fault that could have contributed to the cause of the accident.
    – alephzero
    Feb 12 '19 at 14:32
  • Are the rims identical on both sides?
    – Zaid
    Feb 13 '19 at 8:44
