I’m failing inspection because my wipers don’t return home on my 2006 accord 4-cyl.
If I turn the wipers on for a second, they will end up straight up on my windshield. I have to hold them on for some amount of time guessing that they will end up horizontal at the bottom of my windshield.
I’ve got out of my car and pushed them back down before, which I heard was bad, but couldn’t drive with them up. The problem started when I used them with ice on my windshield.
I have the whole assembly out. Cogs look fine.
On the plug, with the engine running, white wire has 12.6v, green has 13.8 v and the yellow has continuity to the black. The yellow and black wires both have intermittent continuity to my batteries negative post. To me that seems like a problem but I can’t find a wiring diagram on it.
I saw a video where someone hammers out a tab that stops the linkage arm, but i see no such tab here. Anyone have any ideas?
