I have a 2005 Ford F150. The transmission starting having problems shifting today. When I checked the fluid, it shows to be way over full on the dipstick. I have not added any fluid since I have owned the truck, and when I bought it, all the fluids were at proper levels. What would cause the transmission fluid to now show over full and the trans to not want to shift properly?
  • Welcome to Motor Vehicle Maintenance & Repair! How exactly did you check your fluid? – Pᴀᴜʟsᴛᴇʀ2 Feb 10 '19 at 1:12
  • On level ground with truck running. Truck had been running for over an hour and was operating at normal temp. – Kevin Callaway Feb 10 '19 at 1:14
  • Good, good ... just making sure :o) – Pᴀᴜʟsᴛᴇʀ2 Feb 10 '19 at 1:19
  • Is the coolant level a bit low? – chili555 Feb 10 '19 at 1:43
