I have had problems with my 2012 Nissan Note (the boxy model). The battery would be flat after a couple of days, even when driving occasionally. After leaving the car parked and locked for 20min, there was a 1Amp drain on the battery
I think I have traced this to the trunk, which was not properly locking the door (mechanism was blocked). Is this a plausible cause or should I look for other faults?
After this fix, the drain is down to 0.1 Amp. Does anyone know what the nominal level is for this model?
