Every time I go to pump gas in 2009 ford mustang. Almost every gallon that pokes in to tank makes the nozzle trigger pop back like if it was full. It is annoying to hold it and still pops back out. Basically every gallon I pour in it gas pump trigger like when it fills up so gassing it takes longer than even if I hold it with my it still pops it out like if it was full.
Welcome to Motor Vehicle Maintenance & Repair! What exactly is your question?– Pᴀᴜʟsᴛᴇʀ2 ♦Feb 6, 2019 at 22:56
Perhaps you need to allow the fuel in at a lower rate - try 1/2 or 1/3 and not fully open on the pump trigger (some pumps deliver faster than others - have you changed station?)... Because as the fuel goes in - the equivalent amount of air must come out...– Solar MikeFeb 7, 2019 at 9:36
@SolarMike I have done maybe 5 different stations in different cities as well. The mechanics at carmax cant find anything is so I’ve told.– DaveyFeb 14, 2019 at 23:32
When the car's fuel tank and associated plumbing are operating correctly, the tank will accept fuel as some reasonable rate out of the nozzle at the gas station; that's what you're used to. On the other hand, fuel nozzles (in the USA, anyway) are designed to shut off automatically when the nozzle senses back-pressure coming up out of the gas tank.
What you're experiencing is the nozzle shutting off the fuel flow into the tank because the tank is generating backpressure. Excessive backpressure results when something is broken: it might be a physical obstruction in the filler pipe, or the filler pipe might be partially crushed, or some part of the evaporative emissions system (hoses and one-way valves and such) is faulty.
You'll have to carefully inspect the system, and compare it to a stock, properly-operating one. The car's OBD system may also show a trouble code that'd give you a clue; many auto parts stores will connect their code readers for free and read any resulting codes.
The gas tank on my F250 has a venting scheme (with an inline charcoal filter) that's gotten clogged over the years. This causes the pressure back-up that kicks off the gas nozzle. Proof: Disconnecting the filter hose cured the problem temporarily. Feb 7, 2019 at 12:50
Nice I do hope these people find the issue if not I told better start a whole completely new fueling system
