I have a 2008 Honda Accord and for some reason pump keep over flowing with bubbles. I tried changing out the o-ring and replacing the fluid, but the new fluid comes out bubbling also. I don't know if I have to change the pump itself?
    Is it losing fluid at all? Did you change the o-ring in an attempt to stop the bubbles or was the o-ring seeping? Feb 1 '19 at 11:16
  • It could be the position of the return line in the aftermarket tank that is causing the bubbles. If it is system cavitation then it is the pump itself.
    – Moab
    Feb 1 '19 at 23:41
  • The pump is getting air ; most likely caused by low oil level. Feb 2 '19 at 16:53
