I was recently caught out with a flat battery. I want to buy a jump battery to make sure it doesn't happen again. My car is a BMW 3 litre, 6 cylinder diesel that will need somewhere around 500-600 cranking amps. All the jump batteries I can find here have only 300 cranking amps. If I connect two of those batteries to my car at the same time, will that give me the 600 cranking amps I need?
10
    Cant you use a battery-tender? Cheaper and your unused jump battery will probably go bad soon anyways. Or just get some jumper cables. Surely there is someone else with a car nearby should you need a jump-start once again?
    – Daniel
    Jan 30, 2019 at 16:37
  • The car is a 4WD and I am often in the bush.
    – bpolky
    Jan 30, 2019 at 16:51
  • Fit a second battery in the boot and use a split-charge system, then if you need to "help" the primary vehicle battery you can...
    Jan 30, 2019 at 16:54
  • I am looking for an answer to my question about connecting multiple jump batteries. Thank you.
    – bpolky
    Jan 30, 2019 at 17:01
  • Well, I was hoping to offer you a sensible solution, at least, better use of your money than your idea of buying two jump batteries... But your money, your choice.
    Jan 30, 2019 at 17:10
you can. As long as you hook all positives together and all negatives together, the amperage stacks. DO NOT CONNECT RED TO BLACK OR YOU WILL EITHER EXPLODE A BATTERY OR FRY YOUR ELECTRONICS
    and you have the space to make reliable connections...
    The amperage stacks in theory. In practice, the different resistance of the different battery hook-up connections means it won't stack very well at high currents. With 500A current, a resistance of 0.001 ohms will drop half a volt.
    – alephzero
    Jan 30, 2019 at 17:51
  • i didn't want to get into electrical theory since it wasn't necessary. I won't claim my math is perfect, but e = 500 / .001 comes out to .17 volts. An alternator won't notice the difference.
    – John Lord
    Jan 31, 2019 at 22:26
