I know my question is out of topic but could anyone tell me if Benelli TNT 150 has 4 valves or 2? Internet wasn't helpful. I am also confused between Benelli TNT 150 and TNT 15.
Thanks
EDIT
To make my mean more clear, I added this as an opposition to the David's answer where it said it has 4-valves. In other words, I said internet wasnt helpful cause it resulted into different answers.
The bike is equipped with 149.5cc single-cylinder 4-valve engine that produces 14hp at 9000 rpm and 11.5nm of torque at 7000 rpm. It has two spark plugs, while the basic model has a single spark plug. The advantage of having two spark plug is that the fuel consumption of the bike will be good.
  • Lots of errors in that quote - is it from the original manufacturer? If not they may have posted the wrong write-up meant for a different machine...
    Feb 2, 2019 at 9:38
The internet was easily helpful to me. I searched for "Benelli 150 TNT" and quickly found this page, which informed me that this motorcycle has an engine with 2 valves.
  • @Moab Nice edit! Jan 31, 2019 at 17:47
  • You are welcome David!
    – Moab
    Jan 31, 2019 at 19:57
  • Not so fast Sir. You think I didnt search on the internet. When I said it wasnt helpful, I was referring to paradoxical information. Some says it has 2 valves while some other says it has 4!
    – lonesome
    Feb 2, 2019 at 8:30
  • What makes it even worse is the fact that in some cases, they confused TNT 15 with 150.
    – lonesome
    Feb 2, 2019 at 8:31
  • @lonesome The page you cite in your comment shows a TNT 150i, a different machine than the one you asked about in your question. The TNT 150 motor is air-cooled and has 2 valves; the TNT 150i motor is oil-cooled, has 4 valves, and produces more power. They also, at least, have different bodywork and different paint schemes. Feb 2, 2019 at 18:07
