My water resevoir has a hole in it, the vehicle does not overheat, but the water boils out like an eruption. will replacing the resevoir correct this problem?
Yes, fitting a new reservoir will enable the system to run at the correct pressure.
Make sure you use the correct antifreeze in the correct ratio for the car and season.
| improve this answer | |
