I have only one question!
So what I've heard, it's bad to have air left in the coolant system!
So my question is, can air get inside the coolant system if I just take off the radiator cap to check the coolant level (would it cause problem or is it just totally fine to check the level and I don't have to worry about air getting in the coolant system)?
Thank you for your answer!
    If your cooling system has an expansion tank, you don't need to worry. In any case, every car I've driven in the past 40 years or so had a translucent plastic expansion or header tank, so you could see the level without taking the cap off at all. – alephzero Jan 25 '19 at 19:12
For the most part, checking the coolant level in the radiator will not introduce air into the system. So don't be afraid to check your coolant levels!
With that said, there are a couple of things you should know. There are (for the most part) two different types of coolant systems.
  • Expansion tank - This type of system is basically a closed system. It will most likely have a clear (or semi-transparent) tank which has the pressure cap on it. This circulates the coolant through it and allows a place for the air in the system to be captured. You use the coolant levels in the tank to determine overall whether you need to add coolant or not.
  • Recovery tank - This type of system uses a bi-flow radiator cap in it, usually on the radiator itself. This radiator is capable of flowing in either direction. The idea is for the air to flow out through the cap and through the tube, down to the bottom of the recovery (or overflow) tank and vent to atmosphere through extra coolant which is in the recovery tank. This happens as the system heats up (and pressurizes). Then, when the system cools down (and creates a vacuum), it sucks coolant back into the system from the bottom of the recovery tank. Recovery tanks are usually semi-clear as well, which allows you to see the amount of coolant in it and can adjust accordingly.
Please note, some systems still require burping. These are most often ones with a recovery tank on them. Not all will need it, but some will to allow you to remove most, if not all of the trapped air in the system. Yes, trapped air is usually bad for a cooling system, because it can introduce hot spots. Air allows steam to form. Steam cannot remove heat from the engine anywhere close to how coolant can. Keeping it full is definitely something you need to do, but once you get it full, keeping it there is usually a matter of just checking the level in the recovery or expansion tanks, both of which can be done without removing the radiator cap. As long as there's no failures in parts of the system (i.e.: blown hose; bad radiator cap; blown head gasket; etc), you really should have to worry about it.
  • So if im correct i can either check the coolant level by taking off the radiator cap or checking the expansion tank/ the recovery tank :)? – MasterChief Jan 26 '19 at 16:00
  • And there will be no air getting in the system ? :) Am i right ? :) – MasterChief Jan 26 '19 at 16:00
  • @MasterChief - I won't say "no air", but would say no significant air ... nothing which is going to create issues. Don't point the car downhill when you are checking it, though ... you will get spillage, which will cause air to get into the system. – Pᴀᴜʟsᴛᴇʀ2 Jan 26 '19 at 16:02
  • And one more question :) – MasterChief Jan 26 '19 at 16:04
  • So if im right, the same amount of air will get into the system (which is as u said not much) if i check the coolant level by taking off the radiotor cap, and if i check the level of the coolant level by taking off the expansion tank cap or if i spill some coolant in the expansion tank (if i see its low) ? :) – MasterChief Jan 26 '19 at 16:06
