I am trying to solve my cars long issue in idles again.
Cleaning the ICV did the trick before but it keeps coming back and I don't know what else to check. Here's the link in my previous question.
What I did was to replace the intake filters, change oil and now looking at MAF sensors.
Is this related or even worth the try? If so, is it okay to clean MAF using MAF cleaner? Can I use electronic contact cleaners too? Is there really a gain in cleaning MAF and other contacts around the intake system?
What I already did:
  1. Change spark plugs
  2. Changed oil
  3. changed filters (air and oil filters)
  4. check leaks - no leak
  5. heat sensors - I think it is fine, I have no check engine
Apologies if I have a lot of questions. If anyone can point to possible solution, I'd appreciate it.
Note: I stumble on this site while googling for what to check. And so I ask here for confirmation.
8
  • Have you tried connecting an OBD2 reader to see if the MAF is returning sensible values? – HandyHowie Jan 25 '19 at 10:00
  • I'd be tempted to re-route the crankcase breather into a catch can instead of back into the air box. – Steve Matthews Jan 25 '19 at 12:12
  • @handyhowie I don't have that and that is way technical for me but I appreciate the response. – L42 Jan 25 '19 at 13:51
  • @stevematthews Is that the little hose on top of the crankcase going to the intake pipe? what do I do with it? and what is a catch can? thanks appreciate it. – L42 Jan 25 '19 at 13:53
  • This hose releases excess oil pressure from the engine block / sump so you get hot, oily air coming out of the pipe. The emissions laws for all brand new vehicles state this must not exhaust to atmosphere. However, once a vehicle is in use, these regulations do not apply. A catch can is a part fitted to performance and Motorsport vehicles to catch excess oil from the oil breather so it doesn't get sucked into the air box. This hot oily air may be what is fouling your ISV. – Steve Matthews Jan 25 '19 at 14:37
