2011 Dodge Journey Mainstreet 2wd 3.6L V6 100k miles
Check Engine Light on, first read Low Voltage
- replaced Battery
Check Engine Light came back on, 2nd read Cylinder 2 misfire, & Thermostat
- replaced coil & spark plug #2
Check Engline Light back on, 3rd read only mentioned the Cylinder 2 Misfire
- ???? Don't know what I should do next.
Some issues I've noticed:
- Heater doesn't fully heat.
- Burns fuel fast.
- Huge squeaky noise coming from a belt on passenger side under the coolant tank
I replaced the coolant tank about 6 months ago due to a leak, which I only noticed after my son moved my car and there was puddles everywhere. It did overheat a bit, as I was unaware there was an issue (no warning light from car given -_- )
I've checked hoses and wires and they all still seem pretty solid (not a mechanic here). I get my oil changed often, fluids changed and topped, I have the dealership check for maintenance repairs often too. So far though, I haven't had to do much. Now it's going down the drain. I will be having the internal thermostat replaced this weekend, and having the other spark plugs checked for any other faulty wires or whatever else. I just don't have hundreds of dollars to keep throwing at this issue. Any help and guidance is appreciated!!
