Where is the wiper relay located on 1997 f150? My wipers only work on one speed. The windshield washer works well. I already replaced the switch, old switch handle was broke. The wipers still don't work. I can not locate the relay. I believe that would be the next step
1 Answer
Its located in the Power Distribution Box in the engine compartment, Relay position 3 in the image below
Is it possible to visually inspect a relay and see whether it is good or bad? like fuses? or we need to take them to an electronic shop?– gotaJul 19, 2019 at 10:24
