Hi I noticed a small rattle sound when turning a bend while free wheeling. The mechanic found a horizontal bit of play in the right hand outer cv joint. We replaced the whole drive with second hand one but this one has the same problem but a lot less. So I took the old one home and removed the protected rubber and cleaned it out. And now I can see indeed that the whole outer cv joint has a bit of play and can slide a bit in the groves. I looked at some YouTube videos and know that the cv joint is kept in place with a circlip. And that you can take it off in the vice and give it carefully a few blows with the hammer. But even if I take it off I am worried that I still can not see what side is worn either the drive shaft or the outer cv joint. Is a complete new drive shaft now the only thing to do? If there are cv joint problems you expect some worn metal balls or the housing of it Regards Hans Stofberg
  • Welcome to Motor Vehicle Maintenance & Repair! Jan 16, 2019 at 19:52
Not always. As you surmised in your question, you can sometimes replace just the CVJ part of the axle and put it onto the end of the old drive shaft. This may come in handy where the outer CVJ is bad and the inner is good, or visa versa. You can sometimes save money by just replacing the single CVJ ... however, in practice, most of the time it just make sense to change the whole thing. You have to figure, if one is bad, the other is worn, so may go out at any time. Secondly, you have to figure what your time is worth. It is a lot easier to change out the whole axle (in most cases) than it is to try and change out a single CVJ. I putzed around with replacing a CVJ on one end and it took me an extra two hours after I had the axle out to get it changed ... what a PITB (mind you, I didn't really know how to deal with it ... I got frustrated at one point and forced it, which made it pop together with a pop and was good to go ... sometimes knowing ahead of time can save you big, lol!) Changing out the entire shaft can save you a lot of time and frustration. If the pocket book can afford it, it's not a bad idea.
If there are cv joint problems you expect some worn metal balls or the housing of it?
If I have problems with the joint, really it doesn't matter to me what is bad, the ball or the joint ... it's bad, so needs replaced. I have, however, assumed you're going to see wear on both sides. I would never try to "fix" a bad CVJ, as what you are describing in your question would only be a "stop gap" measure. It won't fix it permanently.
    Thanks its great to get some advise. Finely I located an new dr shaft for 240 euro I will try to get it i bit cheaper. Toyota wanted 850 euro for the genuine part. Mister parts had send me the wrong one but that was only 140 euro. Jan 18, 2019 at 14:41
