it’s done this twice in exactly a week and every time I take it to the mechanic the check engine light turns off and they don’t do anything. It’s a 2009 Chevy Aveo
3Manual or automatic? How high are the RPM you're reaching? The CEL will reset after some time if the error condition does not repeat, so have it scanned sooner rather than later next time.– EᑎOTJan 8, 2019 at 21:44
check engine light should store a code for roughly 50 on/off cycles for a vehicle– schizoid04Jan 8, 2019 at 21:45
@schizoid04, it differs by manufacturer.– EᑎOTJan 8, 2019 at 21:46
It's probably your IAC valve or Idle Air Control valve. It regulates idle speed. Sometimes they are dirty and can just be cleaned. A new part cost around $20-40.
Another possibility is the throttle body is dirty. This happened to me, in a 2009 Chevy Aveo, but at higher speeds, over 50 MPH, so not a big chance for the lower speeds, but adding this answer in case someone else has the issue at higher RPMs.
