My car is creaking whenever I turn at slow speeds, and I'm almost certain that its the power steering rack and pinion (and probably sway bar) bushings that's causing the noise.
Question: If they are not cracked or damaged can I just lubricate them? My concern is that this might stop the noise while at the same time prevent the bushings from working properly.
Don't think this matters, but my car is a 2011 Honda Civic with about 100,000 miles.
