I recently changed the radio on my Honda Civic and after I installed it I realized my key wasn't locking the doors. I replaced the battery on the key and still nothing. I also noticed that the power locks only work when the car is turned on. When its off the power locks don't work at all.
I also tried reprogramming the key but i get nothing. And I also checked all fuses. They all work. And same problem with the lights. Usually when i would turn the car off the lights would come on until I locked the car but now they don't turn on when the car is shut off. I have to manually turn them on.
  • I suspect that either the wiring harness adapter used to connect the new headunit is incorrect or faulty - have you tried removing the new unit to see if the issues go away? – motosubatsu Jan 2 '19 at 10:48
  • Yea i unplugged it and nothing. – Gabriel Villa Jan 2 '19 at 15:55
  • Did you replace it with the stock one? Definitely sounds like something has got the car's CANBUS sulking. Has your car got IMID? – motosubatsu Jan 2 '19 at 16:29
