Even after warmed up, the tailpipe has a small but steady amount of water vapor. The weather is cold, but the car. has been warmed up. There is no loss of coolant from overflow tank or rad. Steam and drops are clear and have no smell. When I swipe my finger on the inside of.the pipe I get soot/water. Just got this car and apparently it has been doing this for years.
Perfectly normal operation. One of the byproducts of combustion is water or water vapor and when it is cold outside the vapor condenses. However I wouldn't drink that water because it has all kinds of nasty stuff dissolved into it most of which are poisonous. Apart from how you engine performs there is nothing to worry about.
| improve this answer | |
