Was riding down the road and the bike lost all power. Checked starter relay fuse was good. Put key in ignition absolutely no power at a with the exception of the clock
  • There are so many things that could cause it. I'll try to get some specific information. Did you try to start from a roll? First thing I'd do is to check the wiring from alternator to spark plugs to see if there is a broken circuit anywhere. I assume it's not fuel supply related because you do not see any lights on the dash and the ignition does nothing. – Ghukas Dec 31 '18 at 22:20
