I have seen several comments online here about the same issue that I am having. Headlights, turn signals, brake lights, etc all work, but the dashboard does not function, I cannot see gauges for fuel, water, RPM, etc. I was informed by a local Toyota dealership that the issue is I need a combo meter (whatever that is) installed and the cost will be around $800 installed and a day to do it. While I am not mechanic, I purchased a fuse meter to check the fuses located under the dashboard. They were are good. I realize there are "fuses" under the hood, but again I am not a mechanic and decided that was above my knowledge. I would appreciate any comments with no dashboard lights and if the fix price is reasonable. THANKS!
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Dec 31 '18 at 19:42
  • Are you saying they don't function, or just the lights are out? Anyway all i can suggest with lmited knowledge is to check the ground on the dash. – John Lord Dec 31 '18 at 20:56
  • The lights are out; any info would be great. – JCM Dec 31 '18 at 21:14
  • How could I check the ground? – JCM Dec 31 '18 at 21:18
