I've got a 2004 ES330 (2nd owner) with roughly 315,000. We didn't pay much for the car in 2012 with 164,000 miles. So, i've never gone overboard in maintenance of it. A year ago, when it was time for 2017 annual emissions testing, I had a persistent P0430 that failed me. Out of desperation to avoid the cost of replacing the front/left CAT, I ran a bottle of Cataclean through, and darn if the code didn't go away on its own (no reset!), and I passed.
However, the code did returned back this past summer at some point. It was originally triggered I think by a misfiring coil pack on #2. I had replaced it with a Denso (twice as the first one failed after a month). The misfire issue ceased. But I do highly suspect that it fouled the front CAT some (and the P0430 made sense). But just before testing this year, I discovered I also had a P2241. So I replaced the front/left A/F first. That nixed the P2241, but the P0430 has remained. So, since it got me through emissions last year, I again ran Cataclean through, but no joy. After a couple of tanks in between, I repeated the Cataclean. Again no joy. :(
So I started looking at the CAT being clogged/failed. But, no tell-tale signs of it save for reduced mileage. Good power and acceleration at high speed still. Idles very smoothly. Also, good puffing exhaust at the rear (though I know this isn't definitive since the two banks merge post-CATs). So, I decided to replace the Bank 2 downstream O2 (again a Denso).
While I had the old one out, I decided to stick my handy new Teslong borescope into the downstream port. I've attached some pics of the tail end of the Bank 2 CAT. Definitely shows some deposit at the lower end of the substrate. But it is white, so I suspect phosphorous and/or ash.
This looks like ash build up to me, but I'm NOT a trained mechanic with emissions expertise. Hopefully some of you are! :)
It appears that at least part of the substrate's channels are not collapsed. I could've open the upstream sensor port of put a bright light in to make a better determination.
I also decided to look the other direction, and there was white debris trailing down the bottom of the pipe. I know substrate could be crumbling out. But it was a very windy day, and as I was scoping it, wind was whipping all around me and into the pipe. The debris blew around like styrofoam beads. Ie, it was very light material. It almost looked like the white debris on the ends of the lower substrate getting blown out of the CAT. Which makes me wonder if the Catacleans did have some positive effect in dislodging some of the build up.
This must be the same white material from the bottom side of the substrate. It is light weight too. The wind blew this stuff around like Styrofoam beads. This also make the think it is an ash of some sort. I would think that crumbing substrate would be more weighted down with metal oxides.
So, after installing the new downstream Bank 2 O2, I went for an hour's drive out on the Interstate at 80mph. The P0430 didn't clear, however, now I'm also showing a pending P0420!! I can see the Bank 2 CAT being fouled by the misfire (and/or the cause of the P2241 issue in Bank 2), but now both banks under efficiency??
While on my Interstate drive, I did have OBD Auto Doctor running on my Macbook Pro. Below are a couple of screenshots from that capture. I think the downstream sensors are reading correctly, but now that I'm suddenly seeing codes on both banks, I'm suspicious that something else further upstream is causing these.
Using OBD Auto Doctor (paid version), I captured some plots of the upstream and downstream sensors while on the Interstate drive. Here I had slowed down for a cop helping a stalled motorist. Then I promptly resumed my cruise speed. Using OBD Auto Doctor (paid version), I captured some plots of the upstream and downstream sensors while on the Interstate drive. Here I had slowed down for a cop helping a stalled motorist. Then I promptly resumed my cruise speed.
Yet another plot while holding 80mph under cruise. The downstreams are calmer, but still look more jagged that I would think they should be. Yet another plot while holding 80mph under cruise. The downstreams are calmer, but still look more jagged that I would think they should be.
I've still got to check items like EGR, PCV, cracks in intake or exhaust, the gas cap (it's original), and the thermal gun test pre- and post-CATs. The car is old, and very high miles, and we've gotten our money's worth out of it. But it drives and runs nice still. I hate to think of replacing both CATs on a vehicle this old though.
What REALLY bites is that the state of Tennessee voted to end mandatory emissions testing around Nashville that took effect back on July 1st of 2018. Yet, due to EPA bureaucratic red tape, yadda yadda yadda, the annual emissions testing requirement won't actually end for another 2.5 years!! I don't think I can successfully dodge tag renewal that long! :)
I've read that taking the CATs off and soaking them in a solution of citric acid or Dawn detergent can have a positive effect on efficiency, maybe enough to get passed for emissions. But that is still a lot of work to get at the rear bank and what not.
From what all I've described, along with the scope photos, what would some of you suggest before making the really painful, yet ever looming closer conclusion that in fact one or both CATs are beyond salvation?
Thanks!
Mark
UPDATE 1: Adding Freeze Frame data
UPDATE 2: Adding graphs with LTFT B1B2 Idle and 80MPH Cruise Control (CC).
Please excuse the number of them as I added more than just idle and 80mph as it appears to my untrained eye that there's a weird disparity going on between LTFT B1 vs B2 in many cases. What would cause this?? I would think fuel supply to both banks would be on par with each other.
Why would one bank be appearing to get more fuel than the other??? Timing? Fuel injection issue? Fuel economy is down, so something is telling ECM to feed more fuel than normal, and it appears to not be spreading it equally between each bank. I suppose a more heavily degraded catalyst on one bank could cause this. But is there anything else upstream that might also cause this? I've read that a new CAT will end up suffering same fate if an upstream issue is really to blame.
20181230 1239 31 idle begin1 warmed-up 20181230 1239 31 idle begin1 warmed-up in-driveway
20181230 1317 onramp 20181230 1317 interstate-onramp approach and turned onto
20181230 1323A 38 accelration 80MPH on-cc 20181230 1323A 38 merge+accelration to 80MPH then on-cc
20181230 1324 39a 80MPH on-cc level cruise at 80mph on-cc
20181230 1327B 39 80MPH down-up-hill on-cc 20181230 1327B 39 80MPH down-up-hill on-cc
20181230 1328 39e off-cc 80mph cruise control disengaged - foot off gas pedal
20181230 1338 LT DIFF B1B2 39h 4000RPM burst 50-60mph on country road ending with 4000rpm acceleration burst
20181230 1355 39 end2 idle Back home, driveway, idling - Note persisting diff in LTFT B1 vs B2 while A/Fs and O2s now calm!
7
  • You probably need new cats. What are the fuel trims idle, and cruise? Any exhaust leaks? What does the freeze frame show for set conditions? – Ben Dec 29 '18 at 16:24
  • Just added FF data. I will be taking it back out this morning for another long drive. Will snag long and short-term trims then. I know these CATs are old, so that says a lot right there. But if soaking them in a solution would get me past emissions, then I'll try that before replacing them. I didn't know if what them borescope showed was a show-stopper or not. From other images I've seen of clogged or burned-out CATS, these look not so bad. But if they don't work anymore no matter what, I'll have to make a tough call. – MJBeaten Dec 29 '18 at 16:51
  • Some one elsewhere suggested non-foulers, but I've read that on re-inspection after failure, they scrutinize the CATs visually more, and I don't see how a trained eye wouldn't see them straight away. Thanks for replying! – MJBeaten Dec 29 '18 at 16:51
  • BTW, what is the best way to go about trying to detect any exhaust leaks? I know you can use propane for vacuum leaks, but not sure if there are similar tricks for exhaust leaks. – MJBeaten Dec 29 '18 at 16:53
  • You could use a smoke machine or have someone plug the exhaust and listen. Pinholes in the cat or around either of the sensors are enough to throw things off. As far as nonfoulers it depends on where you live. You can usually find the inspection criteria on google for your state. Another thing to check would be the mode 6 values for the cat monitor if its just barely failing you can probably sneak through an inspection. – Ben Dec 29 '18 at 17:27
