I have a 1.5-year-old (mileage ~7000km) Volkswagen Vento with 1.6 MPI Petrol engine. Recently I noticed that my coolant level was below minimum and my engine oil level was higher than the max on the dipstick. I went to the authorised Volkswagen service centre in my city to get the car inspected. As per them, it is normal for the coolant to get consumed with usage and higher than max engine oil level does not cause any harm to the engine. When I got the car serviced around 6 months back from the same service centre, I was told that Volkswagen uses lifelong coolant (G-13) which doesn't need replacement for 4-5 years (or 40k km). Now they are contradicting themselves saying that coolant is consumed with use and they just topped it up back to normal.
It would be really great if someone can advise me if it's fine to use the car with a high level of engine oil and if the coolant level can reduce on its own without some kind of leakage.
EDIT - Following is an image of the dipstick with current oil level
