Driving home in my Subaru WRX after Christmas with my in-laws, I first noticed a distinct pull to the left under braking, but on checking at the roadside couldn't see anything obvious, so I continued on - then a vibration started. Mild at first, but then rather more pronounced.
And the speed the vibration occurred crept lower over time, from 70 initially, down to 40. And then it really became violent, wrenching the wheel so much that I had to put my hazards on, pull over and stop. On pulling gently away it would be gone again.
So I crawled home the last 30 miles at 30 mph
Tried to reverse into my drive and there was a loud crunch and the car stopped. I got out and found the lower side panel had been almost ripped off by the tyre - the tyre was touching the back of the wheel arch...
I had to move out of the road though so tried to go forwards - and at this point the front wheels were pointing in radically different directions. I put some power down, felt and heard a large crunch and bang, and the folks watching said the wheel jumped forwards to its usual position.
Enough so I could pull forwards to park on the road
I'm thinking the clunking problem I have had with the suspension bushings has developed into a shock actually coming disconnected. What do you think? I'm getting it to a garage anyway, but would love to know.
And this is what it looks like underneath the plastic rod circled has obviously snapped, but it looks like the metal wishbone may have broken some time ago, based on the rust. So maybe that platic linkage is all that was holding it together!
  • Is this the Subie? And pictures would do a wonderful job here ;-) Dec 27, 2018 at 21:20
  • Yes, it's the WRX. I will get pictures in the morning :-(
    – Rory Alsop
    I've seen on some of these Subaru's the control arm rots out. Either that or a broken balljoint. Sub frame rot at the rear control arm mount.
    – Ben
    Dec 27, 2018 at 21:57
  • Jack it up and peer underneath with a torch (but don't get underneath it unless it's safely supported on stands). It should be pretty obvious what's happened. I suspect your wishbone isn't attached in all the places it ought to be. Dec 28, 2018 at 9:53
For the wheel to be moving backwards and forwards I'd suspect the wishbone rather than the shock. If it's the same as the system on my old Forester, they're well known for rusting out (and Ben's comment suggests it is the same) - on the Foz they'd been changed under recall and were rusting out again...
Looking at a diagram online, you've got a three-pointed pressed steel wishbone (which corresponds to what I remember from the Forester). From your description, I suspect the inner front joint has failed, allowing it to pivot around the inner rear joint. It may be that the pressing has rusted through, or that the bolt has snapped - the previous clunking suggests that the bush itself may have failed some time ago and put undue strain on the bolt.
  • Looking at the picture above - you are right. Although it looks like the metal failed first, and I've been driving around relying on the plastic linkage...
    – Rory Alsop
    Dec 28, 2018 at 12:03
  • I'd be surprised if the wishbone drop link would have held up for more than a few miles. Maybe that's the part you were relying on until it got very bad. At least the subframe looks reasonable, my brother has a 2002 WRX and we did the subframe on it last year. I was quite surprised at how readily it had rusted. Dec 28, 2018 at 13:29
  • @Steve I'm hoping that under the rust everything else is good. I'm getting the garage to look at the other wishbone as well though.
    – Rory Alsop
    Dec 28, 2018 at 14:57
  • @RoryAlsop Time to put in tubed control arms.
    – Ben
    Dec 28, 2018 at 23:25
  • I have no idea what that means, @Ben, but realistically I'm going to get replacement wishbones and maybe metal drop links.
    – Rory Alsop
    Dec 28, 2018 at 23:27
