Car overheats and I drove it around the neighborhood and when I came back and turned it off steam came from the belt area yes they are all tight the guy I bought it from said it needed a thermostat and a temp sensor? Could this be the problem
Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Dec 24 '18 at 0:07
Can you give us any more information about the car itself? What is the year/model/engine? Where exactly is the steam coming from? – Pᴀᴜʟsᴛᴇʀ2♦ Dec 24 '18 at 13:04
Identify the component that is creating the steam before replacing random components. Stuck shut thermostat would overheat but you have a leak of pressure. Could be water pump, hose etc. Check first, then replace Why didnt previous owner replace these components?
