I have a toyota matrix 2005 xrs its blows full heat on the drivers side but cold on the passengers side sometimes just alittle heat will come on the passenger side thats when i drive for a bit also when i switch the dial to floor/defrost excetra the right side is cold ive checked the fluids good rad reservoir coolant perfect both hoses going into heater core are hot/hot/warm ok yes videos on theheater blend door actuator on the Pontiac vibe behind the glove on the left side there is none on mine mines on the right side ive looked nothing the one on the right that opens the flap it works where the air filter is it works it opens and closes i checked when i pressed the rec button what do i do wtf should i check i bought a heater blend door there is nothing on the left theres 1 on the right and i see it working plzz help tell me if theres one im missing
Hello, and welcome to Stack Exchange. It's hard to understand what you're talking about with no periods or paragraphs; if you spend a bit of time editing your question you're more likely to get a good answer.– Daniel GriscomDec 21, 2018 at 4:03
Welcome to Motor Vehicle Maintenance & Repair! Does your Matrix have dual climate controls, where the passenger side is controlled separately from the driver?– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 21, 2018 at 13:53
